Author Topic: Controlling track width  (Read 2743 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: October 17, 2017, 07:08:20 am »
I am trying to run a track between an 0805 resistor and a 2mm wide track. My settings are that minimum track width is 0.15mm, preferred is 0.3 and it can go up to 2mm. I don't know if it is because there is already a 2mm wide track on this net but it insists on starting the track on the 085 resistor with a 2mm track, this then can't be routed because it's too wide and 0.3mm is perfectly adequate. Any way around this ? I suspect i can start the track, change it's width and then pick it up again but really ? buggy software or what?
Offline voltsandjolts
Re: Controlling track width
« Reply #1 on: October 17, 2017, 07:34:32 am »
  • Global Moderator
« Reply #2 on: October 17, 2017, 09:28:07 am »
thank you.
