Yeah python looks kind of hopeless Learning C sharp now
. and using OpenMcdf 2.0
Features that I'm missing are following:
Batch create schematic component from template.
For example you could make one resistor and draw symbol for it and add attributes. Then you would have a file with say E12 series resistors with naming convention you like and attributes you want. You'd then point program to template component and component file and it would create whole E12 series based on the file data.
Second feature would be to partly recreate smart grid insert feature from altium designer. So you would have pin data from a micro controller say 144 pins with names and electrical types and you could batch create these to a component, and then use Circuits studios own editor to shuffle these pins around to multiple parts and correct and pretty locations.
Third feature could be to be able to set font sizes, types and such things library wide
