Author Topic: [SOLVED] Re-using a simple circuit  (Read 2785 times)
Offline negativ3Topic starter
  • Country: th
« on: August 02, 2017, 06:31:21 am »
Hi all,
Ok, the ATMEGA328P core circuit with oscillator and ICSP header is really useful for me.
I have the circuit laid down in Schematic, is there any way to save this as a "block" which can be imported into future schematics?
It would be a real timesaver to have this simple core saved as a "part" or "block" which can be dropped into a design.
Possible?
Thank you.
« Last Edit: August 17, 2017, 04:28:28 am by negativ3 »
Offline ataradov
    • Personal site
Re: Re-using a simple circuit
« Reply #1 on: August 02, 2017, 06:43:07 am »
Save as a separate document, and then Ctrl-C, Ctrl-V when you need it.
Alex
The following users thanked this post: negativ3
  • Country: th
« Reply #2 on: August 02, 2017, 07:39:07 am »
Wow, it is that simple... Do the components need to be left un-annotated, or will the component IDs update ok?
Is it the same for the PCB layout?
Offline ataradov
    • Personal site
« Reply #3 on: August 02, 2017, 07:41:34 am »
Components should be renumbered automatically.
I'm not sure about copying PCB layout. Unless you have extremely sparse board, you will have to do layout for each board anyway.
Alex
