Author Topic: Withdrawn  (Read 16499 times)
Offline sk2593@cornell.eduTopic starter
Withdrawn
« on: January 20, 2016, 07:57:11 pm »
Withdrawn
« Last Edit: January 22, 2016, 04:54:19 pm by sk2593@cornell.edu »
Offline drussell
  • Hardcore Geek
Re: Cofounder needed for Battery Charger startup
« Reply #1 on: January 21, 2016, 01:40:25 am »
The startup will manufacture a battery charger which will work with most rechargeable batteries of varying size and shape independent of the battery chemistry.
Oh, really?
And how exactly are you planning on doing that?!
Online John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #2 on: January 21, 2016, 02:03:07 am »
This will be interesting.  :popcorn:
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #3 on: January 21, 2016, 02:14:08 am »
Well at least it's not crowd funded
Oops - yes it is
Call Bob, he's looking for his next IGG project.
Don't ask a question if you aren't willing to listen to the answer.
Offline Towger
  • Country: ie
« Reply #4 on: January 21, 2016, 02:18:21 am »
Must be a windup.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: January 21, 2016, 03:30:48 am »
Battery Charger...
Cornell University...
The powerbank battery has a capacity of 1500 mAh and can juice up in about 5 mins!!!
oh no, not again :palm:
Offline MrSlack
« Reply #6 on: January 21, 2016, 07:18:52 am »
Engineer to MBA ratio FAIL. If there's anything I've ever seen as concrete is that engineering driven startups are the most likely to succeed and MBA driven are most likely to fail.
How many MBAs does it take to change a light bulb? None, they come up with the most contrived way of doing it, get VC funding for their new turn-a-matic light bulb extractor on a stick, hire a series of engineers who laugh their way to the bank, end up blowing the entire budget on apologising on kickstarter for spending the entire VC capital on Herman Miller chairs and cocaine and finally end up sleeping on someone's sofa because they bankrupted themselves.
If you want evidence of this, go and see how many batches of Herman Miller Aeron chairs are on eBay :)
« Last Edit: January 21, 2016, 07:20:42 am by MrSlack »
Offline rx8pilot
« Reply #7 on: January 21, 2016, 07:41:31 am »
Experienced engineer...... No pay........ Startup........ Arduino.......revolutionize.
Sent from mobile device.... Keeping it short and mis-spelled
Offline station240
« Reply #8 on: January 21, 2016, 09:14:50 am »
•   You are an experienced electronics engineer who is familiar with power supply, DC to DC converter, Op Amps, familiar with integrated chips like LM2904 and LM317.
You're planning to use a LM317 linear regulator from The Ark in a high current battery charger ?
Should be interesting to see the heat/smoke output from that.
Offline SL4P
« Reply #9 on: January 21, 2016, 09:18:19 am »
So the MBA has identified the technology and components to be used...
Perhaps they can dispense with the EE, and simply get a PCB designer...?
Offline EEVblog
« Reply #10 on: January 21, 2016, 10:10:46 am »
Oh, really?
My thought exactly.
Do you realise that charging touchy exothermic battery technology like LiIon outside the very strict conditions is dangerous? Right?
Offline EEVblog
« Reply #11 on: January 21, 2016, 10:18:42 am »
I have already developed a powerbank battery that will use this smart charger. The powerbank battery has a capacity of 1500 mAh and can juice up in about 5 mins!!!
So if this your own battery chemistry?
What exactly is the technology innovation in your "powerbank" battery?
1500mAh in 5 min = 1.5A x 12 = 18A charge rate (12C)
http://batteryuniversity.com/learn/article/ultra_fast_chargers
Offline MrSlack
« Reply #12 on: January 21, 2016, 10:38:51 am »
It doubles at an incendiary device of course!
Offline Delta
« Reply #13 on: January 21, 2016, 03:22:39 pm »
Hahaha!
Best of luck with this one Sandeep!
Offline suicidaleggroll
« Reply #14 on: January 21, 2016, 04:14:09 pm »
5 mins charge @7.5 WH = 90 watts/min.
WTF is a watt/min?
 |O
Offline wraper
  • Country: lv
« Reply #15 on: January 21, 2016, 04:24:08 pm »
Offline MrSlack
« Reply #16 on: January 21, 2016, 04:26:29 pm »
Offline tom66
« Reply #17 on: January 21, 2016, 04:52:06 pm »
WTF is a watt/min?
 |O
Hey, at least it's not kWh per hour.
Average charge rate has to be 90 watts per minute.
90 watts per minute makes no sense. Watt is power, you need to use a unit of energy, like joules, Wh, kWh, kilocalories.
What field is your engineering degree in and from what university? If it's an electronic engineering degree I would be asking for a refund.
« Last Edit: January 21, 2016, 04:55:03 pm by tom66 »
« Reply #18 on: January 21, 2016, 06:41:33 pm »
He claims to be from Cornell.  I've been to Cornell before, and I know a handful of people in the graduate EE department there, they're not idiots.  If any one of them ever said "watts per minute" in this context, they'd get smacked in the face.  If not by me, then by any of the students or faculty in the room.
« Last Edit: January 21, 2016, 07:02:50 pm by suicidaleggroll »
« Reply #19 on: January 21, 2016, 06:43:56 pm »
WTF is a watt/min?
 |O
1/60th of a joule?
1/60th of a joule per second squared.  It's an energy acceleration, and makes no sense in this context.
« Last Edit: January 21, 2016, 07:02:40 pm by suicidaleggroll »
Online coppice
« Reply #20 on: January 21, 2016, 06:49:59 pm »
WTF is a watt/min?
 |O
It would be a rate at which a power level is changing. Not a stupid unit, but not the correct one in the current context.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #21 on: January 21, 2016, 06:56:34 pm »
 :popcorn:
« Reply #22 on: January 21, 2016, 06:57:33 pm »
You're right, it could make sense, but not in this context.  I could chalk it up to a typo, but then he wrote the exact same thing again.  Anybody who does not know that a watt is already an energy rate should not be going anywhere near power system design.
Offline SL4P
« Reply #23 on: January 21, 2016, 10:23:51 pm »
ok, I got it...
MBA = master of battery analysis
the charge rate will require battery leads the thickness of your pinky finger +/ -  /sense combined.
Good Luck.
Offline MrSlack
« Reply #24 on: January 21, 2016, 10:53:31 pm »
He's reading this and now has "room temperature superconductors" on the spec sheet.
