Regular panels have issues with the temperature of them, because they get too hot in good weather, so if you concentrate, it needs cooling.
Which means moving parts.
Regular panels work quite well with diffused light and insulation. With this one it will scatter the light and it will not focus it anymore.
Regular solar panels are cheap, if you have to do anything with them, you end up with a more expensive system.
This is a solution looking for a problem. The idea is novel tough.
The next breakthrough will be quantum dots for solar.
