Not a dodgy tech, just dodgy implementation to cut cost as much as possible, and sadly the big names are also doing this to compete, making them with a similar lifetime to the incandescent lamp they are replacing. You should be able to have the LED fixtures have a lifetime in the order of decades, like the discharge lamps are capable of, with almost no loss in efficiency, but the desire to cut a cent of the price of all parts means that the actual LED units themselves are run at high current, hight heat, and thus at a lower efficiency, and with a much shorter operational life, while you can easily derate properly and use the same parts to get light output equivalent, but with a lifetime in decades. Just will cost double the price, and will use marginally less power as well, so long term you will have a lower TCO, but the only thing seen is the initial price, not the long term cost of short life, frequent replacement and higher power use.
