Too much electro smog? Wifi giving you a headache? 5G disrupting your sleep? Here’s the solution: a Faraday cage for everything in your home that emits EMF.
“The Router Cover is a custom Faraday cage invented and designed by us that shields you and your family from about 85% to 90% of the EMF emitting from the WiFi routers. The 10% or so of the EMF that gets out is enough for you to still use your router while being shielded from about 85% or so of the EMF.”
https://smartmeterguard.com/products/router-guardThey appear to be widely available on even Amazon
Or, to protect your loved ones from the RF radiation emitted by the router, you could shut it off or unplug it.
Not much use case for a shielded WiFi router.
Tried a few of these. WiFi keeps dropping.
Not even 'custom'. It's just a run of the mill papers and files holder
I like electro-smog. It feels good on my body.
Of course the usual effect of attenuating the signal is that the transmitter will attempt to increase its output power to compensate...
