Author Topic: Linus Tech Tips Pushes Audio Grade Capacitors  (Read 12783 times)
Offline EEVblogTopic starter
« on: October 26, 2019, 05:55:06 am »
 :palm:
Online TomS_
Re: Linus Tech Tips Pushes Audio Grade Capacitors
« Reply #1 on: October 26, 2019, 08:18:34 am »
Debunk video time?
Offline magic
« Reply #2 on: October 26, 2019, 09:14:50 am »
 :-DD :-DD :-DD
I wanted to rant that coupling capacitors aren't actually created equal but then he talks about power supply caps |O
Most capacitors today are designed for low cost and high reliability
:-DD
screetching noises as you move your mouse around
That's caused by shit grounding and no amount of capacitors will ever fix it :palm:
Offline Rerouter
« Reply #3 on: October 26, 2019, 09:26:37 am »
I just put it down to correlation bias, The motherboards that buy and advertise "Audio grade" capacitors generally are a bit higher spec than the bottom of the barrel Dell / OEM motherboards,
If you look on just about any modern motherboard, the sound IC is practically crammed up next to the 3.5mm jacks, You have to make almost deliberate mistakes to get strong coupling into an area that is generally fairly free top side space.
Offline magic
« Reply #4 on: October 26, 2019, 11:35:37 am »
All you need is to allow audio ground to contact chassis. Or use front panel jacks where the chassis manufacturer made this mistake. Or make a ground loop on the board. Then you get exposed to all the ground bounce of the CPU handling mouse interrupts.
« Last Edit: October 26, 2019, 11:37:26 am by magic »
Offline janoc
« Reply #5 on: October 26, 2019, 12:38:44 pm »
Surprises exactly nobody - the guy is pretty clueless and not only about capacitors. His video about "fixing" videocards with a heatgun is another such example - and earned him a pretty savage response from Louis Rossmann.
If anyone is relying on Linus for their technical information, I am pretty sorry for them.
« Last Edit: October 26, 2019, 12:41:55 pm by janoc »
The following users thanked this post: nctnico, mikerj, Ysjoelfir, Jacon
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #6 on: October 26, 2019, 12:39:28 pm »
OMG, I was just minutes away from starting a forum topic on the same.
I find Linus tech tips to be quite inaccurate. They were also promoting laser and ultrasound based power transfer tech.
And to make it worse, most thing he seems to promote are computer versions of "as seen on TV household tools".
You buy them thinking they'll be super useful, you use them twice then throw them in storage.
What bugs me more, they want things to be impossibly small and yet require them to function equally good.AND THEY ARE READY TO PAY 100X MORE FOR IT.
You can have better capacitor performance just by having more of small ones than a single big one while keeping costs low.. You can't do that in small form factor.
« Last Edit: October 26, 2019, 12:57:12 pm by Raj »
Offline madires
  • A qualified hobbyist ;)
« Reply #7 on: October 26, 2019, 12:48:28 pm »
That guy always forgets to add the "paid promotion" and "infomercial" banners. >:D
The following users thanked this post: janoc, Ysjoelfir, newbrain, Jacon, Chris_Walch
Online wraper
  • Country: lv
« Reply #8 on: October 26, 2019, 01:18:35 pm »
I just put it down to correlation bias, The motherboards that buy and advertise "Audio grade" capacitors generally are a bit higher spec than the bottom of the barrel Dell / OEM motherboards.
I recently bought Asrock A320M-HDV R4.0 for EUR 38 ($42) (without VAT) which is the cheapest AM4 motherboard I could get and it has a few audio grade Elna on it.
« Last Edit: October 26, 2019, 01:20:57 pm by wraper »
Offline StillTrying
  • Country: Broken Britain
« Reply #9 on: October 26, 2019, 01:19:46 pm »
He needs to do one(LOL), on how well these cable-burn-in devices improooove the sound.
https://www.eevblog.com/forum/dodgy-technology/i-wonder-what-effectively-does-this-audiophool-_cable-burn-in-device_/
Online Bud
« Reply #10 on: October 26, 2019, 01:53:28 pm »
Did anyone ever picked useful tech tips out of Linus Tech Tips?
The following users thanked this post: Ysjoelfir
Online Gary350z
« Reply #11 on: October 26, 2019, 02:16:06 pm »
I went to Audionote.co.uk, the website that Linus says helped him with this video. One of their products is tantalum resistors (audionote.co.uk/resistors). Never heard of these and sounds bogus, so I did a google search just to make sure. The search only turned up audiophoolery sites. Audionote says these resistors are "tone-full components", whatever that means. Audionote also sells non-magnetic tantalum resistors, which the say "provide increased texture, a darker background and a greater sense of immediacy". I need to order some for my next project. ::)
Offline StillTrying
« Reply #12 on: October 26, 2019, 02:31:16 pm »
Have you looked at their price list, I couldn't find the resistors.
Edit The 0.5W Tantalum resitors are £3.39 each +Vat and the 2W up to £35.70 + Vat each.
AN SOGON LX96 SPEAKER CABLE 100 METER ROLL  £256,666.66 +Vat.
Yep. Don't waste your time watching his videos.
« Last Edit: October 26, 2019, 02:47:33 pm by StillTrying »
The following users thanked this post: Ysjoelfir, maginnovision
Offline madires
« Reply #13 on: October 26, 2019, 02:36:47 pm »
I prefer rubber resistors as they are damping down vibrations from trucks and heavy tools used by neighbours. Any vibration will change the electron's spin and therefore impact the sound. Tantalum resistors are total nonsense. Get some good quality audio grade rubber resistors! >:D
The following users thanked this post: Gary350z
Offline SiliconWizard
« Reply #14 on: October 26, 2019, 02:52:31 pm »
Indeed, this is nothing else than marketing talk for dummies, but yes it usually comes with better overall design for the corresponding motherboards.
I admit the "Most capacitors today are designed for low cost and high reliability" was pretty funny though
 :-DD
Online Gary350z
« Reply #15 on: October 26, 2019, 02:56:57 pm »
Audionote.co.uk also has a 3.3UF 600V Silver Foil Capacitor for £2,406.25.
Online Gary350z
« Reply #16 on: October 26, 2019, 03:04:03 pm »
"rubber resistors": Excellent. That puts a smile on my face. :clap:
« Reply #17 on: October 26, 2019, 03:21:58 pm »
Nice. ;D
Of course we still shouldn't confuse use cases here.
Caps typically used in power filter sections for speakers, for instance, can have a definite influence on the result. Especially their ESR.
Offline JackJones
« Last Edit: October 26, 2019, 03:30:26 pm by JackJones »
Offline Raj
  • Country: in
« Reply #19 on: October 26, 2019, 05:26:22 pm »
Well, I did find reasons to avoid all the gaming junk, except for good gpu , cpu and save money on PSU by putting 2 small ones instead of a large one.
« Reply #20 on: October 26, 2019, 06:16:35 pm »
Nice. ;D
And that said, here is a similar cap that seems fine for this use: https://www.digikey.com/product-detail/en/cornell-dubilier-electronics-cde/940C6W3P3K-F/338-1141-ND/809434
$10 per 1. A bit less than £2,406.25. :-DD (and actually, I suspect it has lower ESR than the one sold by Audionote.co.uk!)
The following users thanked this post: Jacon
Online wraper
  • Country: lv
« Reply #21 on: October 26, 2019, 06:24:34 pm »
Nice. ;D
But it does not have silver foil  :scared:. FWIW their parts are expensive but many of them not ridiculously expensive.
Online wraper
  • Country: lv
« Reply #22 on: October 26, 2019, 06:29:08 pm »
Although I would prefer them selling tin foil hats instead of tin foil capacitors.
« Reply #23 on: October 26, 2019, 06:36:33 pm »
Silver foil sounds nice. But at the current price of silver, this cap would be worth over 5 kg of silver.  :-DD
Online Bud
« Reply #24 on: October 26, 2019, 06:51:55 pm »
Embedd ferrite dust into the rubber for EMI supression.
