The only way to get 30V across the FET when drawing 30A DC is to have an R
DS of 1Ω. That would only happen if you have it barely turned on, and not surprisingly it will burn if left in that state.
Common sense says that is definitely not in the SOA for continuous operation.
If you have it fully turned on with V
GS at 10V and drawing 30A DC through it, then R
DS should be around 1.7mΩ. So V
DS will be about 50mV, thus it would be dissipating only about 1.5W.
At the full 280A DC rating, V
DS will be about 476mV, thus dissipating 133W. With R
θJC of 0.46 that will give a temperature differential of 61°C between junction and case. You'll need a decent heatsink with forced air cooling to keep that in the SOA (i.e. junction below 150°C, so heatsink below 89°).
The v1.3 datasheet also has pulse lengths measured in Siemens. Why is this so common?
