Hang on a second.
All digital, nothing changes, it is all the same. Correct, but......
Music, making, it playing it, mixing it live for people, etc is a side line.
We have a little problem with jitter. Now this came up because of AES/SPDIF digital formats. They have no fixed sampling rates. The sampleword/bit clock is recovered from the data stream. Based on the data the sample clock can shift a bitt back and forth, jitter. Some people say they an hear it all the time. It is regarded as problem in pro audio that pro devices have an BNC jack to two to accept to to provide word clock to other devices.
Jitter in AES/SPDIF is very subtle. it is a slight FM modulation of all the special components. The same thins happens with tape to a turn table, but is listed as wow and fultter.
Jitter in digital audio systems is real, but the interface chips for along time have done things to reduce it, as talked abut already an external word clock, or using a ddifern PLL to cleanup word clock from the bit recovery clocking.
No is where we get to the snake oil. A Cd spins at it's rate can vary, thus the digital signal coming from the CD/DVD will have jitter. That is true, however after all the error correction the bit clock used to recover the data is not the same or related to the clock that pumps out the samples. For a CD that is defined as 44.1K. If the CD speeds up, slows down, nothing changes the rate the samples are shipped to the D/A convertor. This means no jitter from mechanical system.
Cut, trim, green maker all you want, either the optics pick up the pits and it turns into a sample, or it doesn't.
