Author Topic: Uncoppered circuit boards.  (Read 5976 times)
Offline factoryTopic starter
« on: October 27, 2024, 08:12:45 pm »
This video was posted on another forum, I haven't watched the whole thing, just skimmed to the printing bit.
We already have unleaded circuit boards, now someone has decided uncoppered boards are a good idea, even better a car dashboard. It just looks a terrible idea to me, the unleaded solder they have "printed" will just corrode & turn to dust with moisture & the whole thing will end up unreliable* scrap.
*Ignoring the fact it's a mini, already unreliable scrap to start with.
Edit: To save people having to waste time watching the youtube video, here is a picture from it.
« Last Edit: October 29, 2024, 07:46:39 pm by factory »
Offline Gyro
Best Regards, Chris
The following users thanked this post: I wanted a rude username
Re: Uncoppered circuit boards.
« Reply #2 on: October 27, 2024, 08:29:39 pm »
Your right, there are more sections/threads on this forum, than I have time to read.
« Last Edit: October 27, 2024, 08:43:04 pm by factory »
Offline tggzzz
« Reply #3 on: October 27, 2024, 08:45:40 pm »
Yup.
That's why I only read...
Show unread posts since last visit.
Show new replies to your posts.
Offline Helio_Centra
« Reply #4 on: October 27, 2024, 09:21:13 pm »
I've seen people using a 3D printer to put down traces of conductive plastic before. But since conductive plastic isn't nearly as good as copper or tin you need to make your traces very thick.
Laying down solder traces seems like a bad idea to me because there's nothing holding them to the board.
Offline PlainName
« Reply #5 on: October 29, 2024, 05:20:20 pm »
With that setup he could've milled a PCB and he'd just need a milling bit instead of the solder bath and all that gubbins. The result would be neater and more robust, but I guess the project is about clicks rather than doing a good job.
Online Analog Kid
« Reply #6 on: October 29, 2024, 07:56:37 pm »
Again, keep in mind that this is just a prototype, not a production unit.
The following users thanked this post: bookaboo
Offline PlainName
« Reply #7 on: October 29, 2024, 08:12:15 pm »
A prototype still needs to be reasonably robust, otherwise you end up fixing issues with the prototype that are nothing to do with the project.
« Reply #8 on: October 29, 2024, 08:18:59 pm »
Exactly, it's crap, they would have been much better spending the time taken to create this mess, to learn KiCad and get a prototype board made at one of the Chinese PCB houses.
Normal prototype (& some production boards) boards can be easily modified to correct errors, by cutting traces and adding link wire, or components where needed. Once corrected another board can be made if needed.
Offline langwadt
« Reply #9 on: October 29, 2024, 08:20:01 pm »
only took about a 100 times longer than making it right...
Online Analog Kid
« Reply #10 on: October 29, 2024, 11:11:18 pm »
So what? I don't remember efficiency being one of the criteria for their project. These guys just wanna have fun, and they seem to have succeeded at that. (Including producing a working prototype.)
Offline thm_w
  • Non-expert
« Reply #11 on: October 29, 2024, 11:26:58 pm »
Don't assume malice when they could just be naive. Its a car channel, the picture is of a car, most of their subscribers probably don't even care, and the comments indicate they spent a LONG time making this happen.
But yes, milling bit would have made more sense.
You're too late... https://www.eevblog.com/forum/projects/ive-never-seen-a-circuit-board-made-like-this/
Doesn't really belong in projects to be fair.
Offline PlainName
« Reply #12 on: October 29, 2024, 11:34:42 pm »
Definitely not thinking malice! But they clearly aren't naive - they have a firm grasp of what's required and ways of going about that. I would be very unsurprised if they dreamt this up over a beer (or several) and are doing it like this because no-one else has, and not because it seemed to be the best or simplest or quickest or cheapest way.
The following users thanked this post: thm_w, Kean
Offline thm_w
  • Non-expert
« Reply #13 on: October 29, 2024, 11:44:25 pm »
Yeah that makes sense.
Would have been an opportunity to draw the design, do a test fit with a piece of machined aluminum sheet, and then just hand it off to another channel as a collaboration.
Clearly there was no real rush here (last channel video 7 months ago).
