Author Topic: Wireless power - again.  (Read 3042 times)
Offline hamster_nzTopic starter
« on: August 01, 2020, 08:09:30 pm »
Just saw this, made me smile.
https://www.stuff.co.nz/business/green-business/122266326/electricity-beamed-to-homes-could-do-away-with-wire-transmission-cables
Emrod has developed a system which converts electricity into electro-magnetic waves that can be sent wirelessly to receivers to be converted back into electricity for use in homes and businesses.
In the long-term, founder Greg Kushnir believes the technology could reduce humanity’s dependence on oil by making electric air travel and shipping possible.
In the shorter-term, it’s being earmarked to deliver power to remote New Zealand homes and island communities, and to provide emergency power when power lines are down.
As we say over here.... Yeah, nah.
Offline Cyberdragon
Re: Wireless power - again.
« Reply #1 on: August 01, 2020, 08:36:40 pm »
So the scammers have graduated from simple claims of charging electronics to the full Tesla quakery of replacing the grid and powering planes and ships... :-DD
They know it's BS...just more scammers.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline joeqsmith
« Reply #2 on: August 02, 2020, 02:24:21 am »
Dr. William Brown
Offline Mr.B
« Reply #3 on: August 02, 2020, 02:38:01 am »
Over the last couple of months Stuff.co.nz have introduced a new by-line that they *stuff* in your face on every article.
“Trustworthy, accurate and reliable news stories are more important now than ever.”
It is a pity their hopelessly inadequate reporters cannot read the by-line.
« Reply #4 on: August 02, 2020, 03:05:36 am »
Newspapers that tell you that sort of thing are rather like broadcasters that claim to be "fair and balanced" or countries that feel it necessary to have "Democratic" in the name of their polity. The latter are always dictatorships and I leave you to work out what that says about the others.  :)
« Reply #5 on: August 02, 2020, 03:45:46 am »
'key' tech is a high efficiency rectenna - https://en.wikipedia.org/wiki/Rectenna - that might be vaild tech, but talk about overselling it!
https://emrod.energy/use-cases/
I guess if you want to power remote Pacific  islands using microwave beams they must be flat-earthers???
Online Circlotron
« Reply #6 on: August 02, 2020, 06:21:46 am »
Same as when they use the word "people's"  :palm:
« Reply #7 on: August 02, 2020, 02:03:29 pm »
Sometimes they go for the full set, e.g. "People's Democratic Republic of <wherever>" and you know that the people aren't getting a look in, there's no democracy and there's no republicanism (small r sense). It's quite helpful really, once you know how to read it.  And people say that Newspeak is dead :)
Offline joeqsmith
« Reply #8 on: August 02, 2020, 03:39:38 pm »
I'm not sure if it was ever actually ever used.  It has a lot of constraints compared with copper wire.
https://livrepository.liverpool.ac.uk/18537/1/ZhangJinwei_Sep2013_18537.pdf
« Reply #9 on: August 02, 2020, 04:08:19 pm »
The "rectenna" is confusingly similar in nomenclature to the "squaerial" which was one time in vogue here in the UK for reception of microwave satellite signals. I had to actually follow the link to discover that the two only bear similarities in being antennae of some sort.
Offline ConKbot
« Reply #10 on: August 04, 2020, 02:58:56 pm »
Man, if 5G make covid, I can't wait to see the turbo pandemic that something like that can make. :popcorn:
Offline joeqsmith
« Reply #11 on: September 04, 2020, 02:21:13 am »
Recent article on rectifying antenna
https://www.stripes.com/news/us/air-force-lab-working-on-process-to-beam-solar-power-from-space-to-earth-1.640722
Old tech, new use
The “spider” project – Space Solar Power Incremental Demonstrations and Research, or SSPIDR – is actually building on technology created decades ago. Photovoltaic beaming, or wireless power transfer, was demonstrated in the 1970s, said SSPIDR project manager James Winter. It’s based on gathering solar energy with photovoltaic cells and then converting it to radio frequency for beaming from antennas to receivers.
That process is used for satellite TV, whereby solar energy is used to propagate radio frequency that’s then sent to the ground for communications. In the case of wireless power transfer, the radio frequency is received by a “rectifying antenna” that converts the frequency back to electricity, Winter said.
“The concept has been around a while,” Winter said. “With normal solar systems, you collect solar energy and convert it to direct current to charge up batteries on a satellite. … With a solar-to-radio-frequency module, there is no storage – you convert the solar energy to direct current and then to radio frequency with integrated circuits for transfer to a rectifying antenna that converts it back to direct current.”
