Author Topic: Library part for IC containing multiple components.  (Read 6230 times)
Offline DenzilPenberthyTopic starter
« on: October 09, 2013, 11:39:01 am »
Hi All,
 All the library tutorials I've seen cover the case where the whole of device is used in one location on a schematic. i.e. the schematic symbol has all of the pins on it.
What I want to do is create a part for a 6x Schmitt trigger inverter. So the schematic will have six inverters and two power pins which I want to split up and place around my schematic
Does anyone have any hints and tips on how to do this?
On a related note, I'm having a play around with existing parts that are like this. e.g. a 4001 quad NAND gate. When I place it on the schematic the NAND gates place one at a time, appearing as IC1A then IC1B, C, D etc then IC2A etc. How do I get the power pins to appear on the schematic?
Many thanks in advance!
Offline senso
  • Country: pt
    • My AVR tutorials
Re: Library part for IC containing multiple components.
« Reply #1 on: October 09, 2013, 12:26:34 pm »
To show the power pins, righ-click in any of the gates, Invoke and click on power and place the two pins where you want.
Never done a multi piece component in eagle, so I can't help you in that respect.
« Reply #2 on: October 09, 2013, 01:21:02 pm »
Aha! well you've solved one half of my mystery though. Thanks.
I'll have a crack at seeing if I can reverse engineer one of the existing parts to see how to create it.
« Reply #3 on: October 09, 2013, 02:27:34 pm »
