Author Topic: Meander function to match the length of the tracks.  (Read 3136 times)
Offline luiHSTopic starter
« on: December 30, 2023, 10:03:58 pm »
Has anyone gotten the meander function, to match track lengths, to work well?
When the tracks are on the same layer, without changing sides with vias, everything works fine. But if the track is cut into several sections when using vias to change layers, then the percentage indicated by the meander function is always incorrect, it seems to indicate the percentage with respect to the track section of that layer and not the entire track length.
My Eagle version is 9.6.2.
« Last Edit: December 30, 2023, 10:05:30 pm by luiHS »
