Author Topic: Alternative to Digi-Key Scheme it  (Read 2637 times)
Offline JesusCastaneTopic starter
« on: May 01, 2020, 10:28:50 am »
Hello,
I'm using Digi-Key Scheme it to sketch some schematics. www.digikey.com/schemeit
Is there any alternative that is open source and/or offline?
What tool do you use to capture some quick ideas about circuits?
Thanks,
Offline Eternauta
Re: Alternative to Digi-Key Scheme it
« Reply #1 on: May 02, 2020, 08:20:21 am »
I found sPlan 7 a good solution for schematics, block diagrams, wiring diagrams for documentation etc etc.
it is not free but the price is acceptable (45 Euro).
« Last Edit: May 02, 2020, 08:23:41 am by Eternauta »
The following users thanked this post: JesusCastane
Online MarkF
« Reply #2 on: May 02, 2020, 03:33:07 pm »
Use the same tools you would use for a PCB layout.
Then, you can proceed directly from the schematic to layout and having a board made if you like.
See the following discussion:
   https://www.eevblog.com/forum/manufacture/are-osh-park-and-kicad-still-a-good-starting-place/?topicseen
« Reply #3 on: May 04, 2020, 09:13:21 am »
I will check sPlan 7, looks good.
I use Altium and I could use it to capture these ideas but just exploring other options that might be quicker
Thanks for your comments
