Author Topic: Altium - Sheet title block in assembly drawing  (Read 4547 times)
Offline Mad IDTopic starter
« on: July 31, 2013, 01:39:17 pm »
Hello, I'm trying to set up sheet title for printing assembly drawings. As used by Altium, my Mechanical layer 16 is linked to sheet.
What bothers me is printing of the bottom assembly where I must use the mirror option. In that case the title block is also mirrored.
Is there a solution for this? I know I could use two mechanical layers, one with non-mirrored title block and the other with mirrored title block.
I appreciate any help.
Thank you!
Offline Ondre
Re: Altium - Sheet title block in assembly drawing
« Reply #1 on: November 15, 2016, 01:01:04 pm »
Hi. Same problem here. Have you solved it in the meantime?
