Author Topic: Any one using Freeroute? I have a question  (Read 1152 times)
Offline julian1Topic starter
« on: January 31, 2017, 05:16:20 am »
I know the general advice is to avoid the autorouter, but I have also read enough contrary opinion suggesting that Freeroute actually does a pretty reasonable job.
Before I go about building the Java app and exporting and importing the specctra design files, I would be interested if anyone knows -
If it is possible to constrain the routing of netlists to specific layers? I have a four layer board, with dual power supplies and would like the IC supplies/ and decoupling to be immediately routed to the reference planes with vias.
Also, is it possible to specify that signal routing should only use the outside layers?
« Last Edit: January 31, 2017, 05:41:43 am by julian1 »
Re: Any one using Freeroute? I have a question
« Reply #1 on: January 31, 2017, 11:22:07 am »
To answer my own question - It looks like I can de-select routing for the middle reference layers, so it only routes top and bottom. Then re-import back into kicad and do the power and gnd vias manually.
