Loading [MathJax]/extensions/Safe.js
Author Topic: Are these power traces a "star topology"  (Read 4356 times)
Offline DmeadsTopic starter
  • who needs deep learning when you have 555 timers
« on: September 10, 2024, 06:10:59 pm »
I am laying out my first 4 layer board (signal+power, GND, GND, signal+power).
This is a hobbyist project AFE for a single lead ECG. The ADC (MCP3202) I am using calls for the power routing to be a "star configuration" and for the power traces to be at least 2 times the width of the signal traces.
I have included pictures of my top and bottom layers (with and without silk screen). The top_no_silk.png has the power ports labeled.
Is this power layout a "star configuration"? (I think this means every Vin has a direct path back to the voltage source -- nothing is in "parallel" so to speak)
Any other tips would be helpful as well!
Thank you!
Offline thm_w
  • Non-expert
Online temperance
Re: Are these power traces a "star topology"
« Reply #2 on: September 10, 2024, 10:06:17 pm »
What you've got is a two return trances carrying some current to power the amplifier and the ADC to a common reference point and the noise across the common return paths is coupled into the ADC input.
This doesn't qualify as a star GND network. The purpose of a star GND network is to avoid coupling return currents into your signal path. Your PCB layout does the opposite and promotes coupling of return currents into the signal path.
A GND plane on both sides of the PCB will be a better solution as it also provides shielding for the very high impedance inputs.
Maybe some common mode chokes will be required for the DC/DC converters.
Offline thm_w
  • Non-expert
« Reply #3 on: September 13, 2024, 08:18:30 pm »
Good video about star grounds for you:
