Author Topic: CADStar question  (Read 4537 times)
Offline RufusTopic starter
CADStar question
« on: November 05, 2012, 02:02:54 pm »
I had to make a rev to a PCB laid out with CADStar (version 12? maybe 13?).
It imported into Altium but with many problems which would have taken longer to fix than the mod so I subbed out the change to a CADStar guy.
I needed and asked for and kept not getting a .PAF file from him which is some kind of CADIF export starting with
(cadif
 (format CADIF 7 0)
 (design
Can anyone with CADStar experience tell me if this is a difficult thing to produce, is it not a standard option?
Offline Mattylad
Re: CADStar question
« Reply #1 on: November 05, 2012, 09:55:03 pm »
CADIF is a standard output format in CADSTAR and can be output in a few seconds using the file export options.
Or it can be output in the batch processor alongside the gerbers.
However the .paf file is only 1 method of assembly data for assemblers to use.
An ODB++ file would be better as it includes the whole board data, this too only takes a minute to produce.
(Assuming the silkscreen layer is not a mess).
Make sure you get the schematic & PCB files.
Then you can use the free CADSTAR design viewer to be able to view them.
Matty
CID+
« Reply #2 on: November 06, 2012, 01:27:37 am »
Thanks for the info I will press the guy again.
