Author Topic: CD4066BE bug in Proteus or I use it wrong?  (Read 3205 times)
Offline XahonTopic starter
  • Country: ru
« on: June 01, 2024, 06:15:21 am »
I have made this test thing to check if CD4066BE works in minimal sample, it doesn't work as I intended
I expected the LED to light up because I push +V to control pin, one of the SIG pins is connected to +V as well and I expect the other SIG_A pin to passthrough current but it doesn't happen
Hardware CD4066BE works fine for me
CD4066BE was added from SamacSys page of the Pick Device manager
« Last Edit: June 01, 2024, 06:22:20 am by Xahon »
Offline wraper
  • Country: lv
Re: CD4066BE bug in Proteus or I use it wrong?
« Reply #1 on: June 01, 2024, 06:22:58 am »
Likely buggy or incompatible model. Also bugs were pretty common in Proteus while using its own models at least in the past. I did not bother emulating anything other than simplest passive circuits in Proteous for a long time as I have better things to do than figuring out emulation bugs.
« Last Edit: June 01, 2024, 06:28:07 am by wraper »
The following users thanked this post: Xahon
