Author Topic: EEG board overheats at regulator and fails USB enumeration.  (Read 2229 times)
Offline dunktraTopic starter
  • Country: sg
« on: August 22, 2026, 08:03:05 pm »
I'm bringing up a batch of custom 8-channel EEG acquisition boards based on an open, published design. MCU is an STM32L433RCT6, ADC is a TI ADS131M08, intended to be flashed via USB DFU bootloader.
Symptom:
-When the board is connected via USB-C to a host (tested on macOS), it does not enumerate at all. I checked with dfu-util -l, system_profiler, and log stream, none show any sign of a device being detected, not even a partial/failed enumeration attempt.
-Within a few seconds of being powered, a specific region of the board — around the LDO regulator (silkscreen ref U10) and a nearby capacitor (C2) — becomes noticeably hotter than the rest of the board.
-With a multimeter in continuity/diode mode (board unpowered), measuring from V+ to GND near that area produces a continuous continuity beep, which I'm reading as a possible short, but I'm open to being wrong about that interpretation.
Scope:
We have 5 boards from the same production batch. At least one other, independently tested board shows the same heat-and-no-enumeration symptom in the same physical location, so this doesn't look isolated to a single unit.
What I have available to test further:
-Multimeter (continuity/diode/resistance modes)
-Basic soldering iron
-No oscilloscope or bench power supply with current limiting yet
What I'm hoping to learn:
-Is this heat + zero-enumeration pattern consistent with any specific failure mode you've seen before (e.g. reversed/shorted regulator, bad decoupling cap, ESD damage, something else)?
-What's the safest and most reliable next diagnostic step, given what I have on hand?
-Happy to share the schematic PDF, board photos, and netlist if that's useful for anyone taking a look.
Offline negativ3
  • Country: th
Re: EEG board overheats at regulator and fails USB enumeration.
« Reply #1 on: August 22, 2026, 09:03:35 pm »
Circuit diagram and photo(s) would be useful.
Offline Renate
    • Renate's Android Page
« Reply #2 on: August 23, 2026, 04:17:32 am »
Well, you said "batch" and "USB" so you could probably use a quick checker (even though this is probably some overall power problem).
You can make this up with either a sa[l]vaged cable or connectors and two LED (no resistors).
If you plug this into a working device the FS (full/high speed) LED will light up, saying, "Please enumerate me".
If nothing lights it's not even asking.
Offline booscrawl
« Reply #3 on: August 23, 2026, 05:04:09 am »
You will need all of these to proceed.
This is pretty unambiguous. Your meter says there's a short. If there's a momentary beep, it could be the capacitors charging up (temporary AC short), but if it's continuous, probably a resistive short.
Do you have ohm mode? How many ohms is the short? Does your multimeter have voltmeter capability or ammeter capability? You could use it as a current-monitoring power supply to diagnose the short if so -- just put it between the power supply and device, but make sure not to blow the internal fuse.
That's actually consistent with a lot of things, and none of them are ESD. I hate to rely on AI here, but my friend at chat.com has some great advice (drawn from this very forum) that I can't disagree with.
Haha, the classic hardware-debugging defense: “Have you considered blaming ESD?” 😄
But USB not enumerating and something overheating makes me suspicious of an actual electrical/design fault before ESD.
A good triage order:
  • Stop powering it if something is getting genuinely hot. Especially if an IC, regulator, or USB protection part is hot enough that you can't comfortably touch it.
  • Measure the power rails. Check USB 5 V → regulator outputs, and look for an unexpectedly low rail or excessive current draw.
  • Check for shorts. With power removed, measure resistance from each supply rail to ground. A very low resistance is a big clue.
  • Inspect USB VBUS and GND polarity/routing. A surprising number of “USB won't enumerate” problems start here.
  • Check the USB data lines. Look for D+/D− swapped, incorrect pull-up/pull-down configuration, bad routing, missing/incorrect termination components, or an MCU that isn't actually running.
  • Verify the MCU clock and reset. If the MCU isn't executing firmware, USB enumeration obviously isn't going to happen.
  • Look at the USB device's power consumption. If plugging in USB causes a large current increase, that's particularly informative.
  • Only then elevate ESD on the suspect list. ESD can absolutely damage a USB transceiver or MCU without leaving an obvious visual mark—but it doesn't magically explain an otherwise healthy board suddenly drawing excessive power unless something was damaged.
Invest in test equipment. Review the schematic for obvious errors. Review the datasheets for the regulators more carefully; they're not as forgiving as other ICs.
BTW, ADS131M08 is not rated for EEG and could possibly transmit shocks to you. These might be better: https://www.ti.com/product-category/data-converters/integrated-special-function/medical-afes/biosensing-afes/overview.html
« Last Edit: August 23, 2026, 05:17:29 am by booscrawl »
