Loading [MathJax]/extensions/Safe.js
Author Topic: Error in LTSPice simulation/Circuit when used the biosensor as Rf  (Read 3840 times)
Offline ZainiiiTopic starter
« on: September 06, 2024, 03:45:14 am »
Hope everyone is doing great.
I am building a circuit in LTSpice using the inverting configuration of the LT1028 operational amplifier. The input signal provided is 0.7 Vp, which is applied to R1 (5M ohm). For the feedback resistor (Rf), I am using my biosensor, whose impedance varies from 10M ohm to 25M ohm. The equivalent circuit of my biosensor is attached in the picture. I want to measure the value of Rf using the formula:
                                                              Rf=     R1 x ( −Vout/Vin)
After R1, the voltage drops from 0.7 Vp to 60 uV before reaching Rf (the biosensor).
I have created a separate circuit in LTSpice representing the equivalent circuit of my biosensor. The values I used for R and C in this LTSpice circuit are based on the impedance analyzer readings. The actual impedance of my sensor is 15M ohms, but I used the values of R and C provided by the impedance analyzer, where R and C are in parallel. The voltage applied to this circuit is 60 uV, but the output I obtained from the circuit is very low (around 0.8 uV), and the waveform after the circuit is not a sine wave.
Given this, the impedance value for Rf that I calculated is incorrect.
I have a few questions:
1.   Did I correctly build the equivalent circuit of my biosensor in LTSpice? If not, could someone suggest the necessary changes to the circuit?
2.   Why am I not getting the correct value for Rf when I use the equivalent LTSpice model? When I use a simple resistor for Rf, I can calculate the correct value using the above formula.
3.   Can someone explain why the LTSpice model of my equivalent circuit alters Vout and why the parallel capacitor significantly affects Vout?
For reference, I will attach the picture and the LTSpice ASC file.
Offline iMo
  • Country: nu
Re: Error in LTSPice simulation/Circuit when used the biosensor as Rf
« Reply #1 on: September 06, 2024, 07:02:40 am »
3. because your LTspice equivalent circuit works as a band-pass at 30Hz.. The 1kHz is therefore attenuated..
Without the 5Meg there it simulates as a low-pass with the knee at 30Hz, therefore the 1kHz is attenuated too..
« Last Edit: September 06, 2024, 07:40:44 am by iMo »
Offline iMo
  • Country: nu
« Reply #2 on: September 06, 2024, 07:21:37 am »
1. my equivalent circuit based on your above picture..
PS: do you plan to use the LT1028 in your real circuit??
« Last Edit: September 06, 2024, 09:35:25 am by iMo »
Offline iMo
  • Country: nu
« Reply #3 on: September 06, 2024, 08:17:57 am »
My thought experiments based on your above measurement method/schematics (no idea what are your eqv. biosensor's values there, but let us target "impedance" Rf=10Meg at 1kHz)..
« Last Edit: September 06, 2024, 10:03:49 am by iMo »
