Author Topic: Gold Plating Artwork  (Read 5225 times)
Offline Falcon69Topic starter
« on: November 19, 2016, 03:20:49 am »
I have a question.
Regardless of what program is being used...
Say you have a PCB you want manufactured, on this PCB you have some artwork or Logo or words or something, doesn't matter, can even be that little open hardware design symbol....anyway......
When the manufacturers do their gold plating process, how is it done?
If I do a piece of art work and say it is an area without soldermask and it is a copper pour layer underneath...will that area be gold plated when it goes through the gold plating process? Or only the areas that are 'PADS' or "FINGERS' or 'THROUGH HOLES' that the gerbers say will be gold plated only?
I'm trying to design something that will really stand out. I want a flat black PCB and I think the gold plated logo would really look nice on it.
Thanks in advance.
Offline Rerouter
Re: Gold Plating Artwork
« Reply #1 on: November 19, 2016, 03:28:59 am »
What you are thinking of is selective gold plating, generally for things like RAM finger contacts, for generic PCB's its a full board immersion, so leaving something exposed would result in it being plated.
« Reply #2 on: November 19, 2016, 03:34:24 am »
So they just dip the whole pcb into the solution of gold and wherever the solder mask is NOT...the gold sticks too?
Offline Fortran
« Reply #3 on: November 19, 2016, 03:35:35 am »
Correct.  Assuming there's copper underneath.
« Reply #4 on: November 19, 2016, 03:37:11 am »
okay, cool. thank you.
Offline amitchell
« Reply #5 on: November 19, 2016, 04:01:14 am »
Yeah just set the layer to Tstop or Bstop. I do it all the time for the board name, my name, revision number and year. It looks slick.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: November 19, 2016, 07:13:19 am »
I also like to do text, in negative copper, and positive silk right over top.  The silk sits down in the depression where the copper was.  It's flat, durable, and cannot be erased without destroying the copper!
Seven Transistor Labs, LLC
The following users thanked this post: salbayeng
« Reply #7 on: November 19, 2016, 07:24:25 am »
what do you mean by negative copper?
And yes, I know about the registration error with the silk screen. Another reason why I am trying to avoid it. Also, it's ugly and doesn't look very clean. It's always off and sometimes (and usually often) unreadable for smaller text.
« Reply #8 on: November 19, 2016, 07:37:02 am »
oh, okay, thats what I was talking about before, about gold plating that if it is exposed, like the pads are. So that will be gold plated as well.
Offline T3sl4co1l
« Reply #9 on: November 19, 2016, 09:36:10 am »
Negative copper, as in, a cutout in the shape of the text.
Just to demonstrate, using my corporate logo: ;)
Copper height exaggerated to illustrate the cutout, and soldermask opening to show the underlying copper (which shows as yellow here, suggesting ENIG or the like).
As mentioned, all exposed metal surfaces get the same plating, whatever it is (bare / OSP, tin or solder, gold, silver..), unless you wish to use a custom process with masking and extra steps that gives you different platings by area (be willing to pay for it!).  Of which, gold fingers is probably the most common, and isn't terrifyingly expensive, but don't expect it on a cheap proto service!
Different colored solder mask regions is also an option, but again, as a custom process, with extra steps, be prepared to pay for it. :)
Online Psi
« Reply #10 on: November 19, 2016, 11:52:46 am »
if you want gold logo/text you need to
1) Tell the PCB house you want ENIG
2) have the logo/text on both the copper layer and on the solder mask layer in the same location.
