Hi everyone,
Long-time lurker, first-time poster. I wanted to share a problem I kept running into and a tool I built to solve it, but more importantly, I want to hear how you all handle this.
The problem: When a single component gets swapped or a footprint is nudged, that change can silently ripple across the netlist, BOM, Gerber layers, drill files, and pick-and-place coordinates. Manually comparing PDFs and spreadsheets under time pressure is a recipe for missing something, and the failure mode is expensive: you find the error after the boards are fabricated and assembled.
What I built: Kontr-Owl is a local Windows tool that diffs eight categories of PCB files—netlist, BOM, ODB++/IPC-2581, Gerber, drill, pick-and-place, PDF, and mechanical—in one workflow. Files never leave your machine, and it generates audit-ready PDF/HTML/CSV reports.
Why I'm posting: I'm not here to just drop a link and leave. I want to understand how other engineers actually handle revision verification in practice. So I have a few questions for the community:
- Do you rely on visual inspection alone, or do you have a checklist?
- What checks do you never skip before signing off on a revision?
- What would make you trust a diff tool enough to use it for final sign-off?
Disclosure: I built Kontr-Owl. There's a 14-day free trial: full features, no license key required. But my main goal here is to learn from your workflows and see if I'm solving a real problem or a niche one. You can read more and access it here:
https://kontr-owl.com/I'm happy to answer any technical questions about how the diffing works under the hood. Thanks for reading.
