Move the feedback resistors also as close to the IC as possible, the feedback net is sensitive to noise after the first resistor.
Yes, I also already mentioned that. And then he moved it only half way.
Goal is:
1. Put R1 where R4 is now.
2. Put R2 south of R3 or R2.
3. Put R4 elsewhere. It's location is not critical.
Doing this makes the path from the +1V2 net of R1 longer. That is not important by itself, but the enclosed loop area is important, and should be minimized.
1. Rotate C2 and C3 clockwise 90 degrees.
2. Put the GND pads closer to pin 2.
3. This reduces the loop area.
It may be better (I'm not sure here) to:
1. Rotate C2 and C3 anti clockwise.
2. Rely only on the GND plane for connection (with plenty of via's).
3. Route the +1V2 in between U1 and the output capacitors to R1.
