Author Topic: Hyperlynx ref file  (Read 1976 times)
Offline xzswq21Topic starter
Hyperlynx ref file
« on: February 08, 2019, 08:32:07 pm »
Hello
I have exported a file to a Hyperlynx file, I checked the menu in Hyperlynx and I assigned some models to the components as following:
now if I open the ref file I see the below codes:
but about the last line, U1, I added it by hand, Do u see any problem?
on the other hand in Hyperlynx from Setup Menu/option/directoris, I added the spice model's path as following:
for example in the path there is a file named op07.cir
« Last Edit: February 08, 2019, 08:35:10 pm by xzswq21 »
