Author Topic: IBIS Models  (Read 3841 times)
Offline AndrewHodgsonTopic starter
IBIS Models
« on: August 03, 2021, 09:40:18 am »
I want to know what the best way to create IBIS models is and whether this is a worthwhile exercise?
I want to create an IBIS model for PCIe gen 3.0 and various other signal protocols but I don't know how to do this? Some components it's very easy to get an IBIS model for but others it's very difficult and I'm wondering if generic models exist that I can edit?
I was sent a s-parameters model by TI as an alternative for one component but I can't convert this into a useful format.
Thanks in advance
Offline tggzzz
Re: IBIS Models
« Reply #1 on: August 03, 2021, 11:49:08 am »
If you are after a generic model, then I would have thought you would be simply looking at a spice model.
IBIS models tend to be used for i/o pin inductance/capacitance/resistance/clamping, and hence are slightly different for each pin on a device.
In addition, "protocol" usually implies operation at a much higher level than individual transistions and bits.
Re: IBIS Models
« Reply #2 on: August 03, 2021, 01:15:32 pm »
Spice models would be useful, but I'm not sure where to locate those either?
I was aware I was misusing the term protocol but I thought it would sufficient :)
Cheers
Offline tggzzz
Re: IBIS Models
« Reply #3 on: August 03, 2021, 01:42:22 pm »
I suspect you will have to decide what aspects you are/aren't interested in modelling, and create a suitable model from spice primitive models such as voltage sources, transmission lines, resistors etc.
« Last Edit: August 03, 2021, 01:43:58 pm by tggzzz »
Offline Shadowfire
Re: IBIS Models
« Reply #4 on: September 15, 2021, 08:14:55 pm »
Generally speaking, you (as a PCB designer) will not make IBIS models.  IBIS models are supplied by the vendor of the IC you are simulating.
