Author Topic: Image To Gerber Converter  (Read 26664 times)
Offline jordileftTopic starter
« on: March 14, 2016, 09:57:50 am »
Hi everyone,
I've developed a software for converting images to gerber files, it works great for me so I thought it could be useful for other people.
You can download it for free but it's been many hours of work, so if it's useful for you any contribution would be really appreciated.
https://imagetogerber.wordpress.com/
Best regards,
Offline BravoV
  • +++ ATH1
Re: Image To Gerber Converter
« Reply #1 on: March 14, 2016, 10:01:20 am »
Interesting reverse engineer tool, downloading ... thanks !  :-+
Offline krivx
  • Country: ie
« Reply #2 on: March 14, 2016, 11:22:06 am »
Is it possible to edit the layers as images, before they are converted to gerbers? In the example shown the silkscreen text is "cutting" into a copper layer, it would be nice to correct that in something like Photoshop.
« Reply #3 on: March 14, 2016, 11:32:41 am »
Of course, you edit your image with Paint, Photoshop or anything similar, save your changes and then load the new image with the app.
Offline doctormord
  • Country: cx
  • !nop
    • #fine_arts & #electronics - 360customs.de
« Reply #4 on: March 16, 2016, 02:42:01 am »
Interesting, how does it works for the drills?
#fine_arts & #electronics  - www.360customs.de
« Reply #5 on: March 16, 2016, 06:17:58 am »
The result for any desired objects of the circuits always depends on its color. If drills have a different color than any other object in the pcb then its perfect, 'cause you can get a direct output, if there are some other objects with the same color you have two options, edit the image prior to using the app or use a gerber editor if you can get one to edit the resulting gerber.
Offline IconicPCB
« Reply #6 on: March 23, 2016, 08:05:38 pm »
Jordie,
Thanks.
I am having some problems
invoking java -jar ImageToGerber.jar results in a bunch of errors
Exception in thread "main" java.lang.UnsupportedClassVersionError: imagetogerber/myJFrame : Unsupported major.minor version 52.0
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
   at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
   at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
   at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
   at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
   at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
invoking java -version offers
java version "1.7.0_95"
OpenJDK Runtime Environment (IcedTea 2.6.4) (7u95-2.6.4-0ubuntu0.14.04.1)
OpenJDK 64-Bit Server VM (build 24.95-b01, mixed mode)
Any hints on how to get it going?
« Reply #7 on: March 23, 2016, 08:33:42 pm »
I think that you need java 1.8 for running it. Try that and let me know!
Offline IconicPCB
« Reply #8 on: March 24, 2016, 03:58:17 am »
Works on 1.8
Will put it through it's paces .
Offline IconicPCB
« Reply #9 on: March 24, 2016, 09:44:47 pm »
Jordie,
An interesting tool.
Have You considered providing a colour pallet rather than colour ( RGB) value input)? This would be less flexible but it would eliminate the ( unnecessary? ) keyboard interaction.
I see that You are using a polygon tool to define the layer content when converting to Gerber. Is there a way to define a small round tool to actually draw the Gerber layer ( as opposed to polygon ). It may be easier to edit the Gerbers when drawn this way. It may also be easier to convert draws to flashes rather than converting parts of a polygon to flashes.
« Reply #10 on: March 29, 2016, 05:51:02 am »
Thanks for your feedback!
I don't think a colour pallet would be a good choice, if some day I improve the current version probably I would add a color "picker", this way you have the same precission while supressing user input.
Initially, this application defined objects as draws as you suggest, the problem is that the resulting gerbers most of the time were really heavy. As many gerber editors have a tool for converting from polygon to draws or flashes I prefer to define everything as a polygon so the application resulting files are as simple and light as possible.
Offline dellsam34
« Reply #11 on: May 03, 2021, 05:04:32 am »
Is this app still free to try?
« Reply #12 on: May 03, 2021, 05:35:43 am »
Yes, it is.  You've got a free limited version  without scaling feature and then you have ImageToGerberFull   and ImageToPcb , this last version allows you to export both gerber & drill files too.
I know that free software is really cool but there are many hours of work behind that, so if you decide to support getting ImageToGerberFull or ImageToPcb it will be really appreciated.  ;)
Offline PeteDD
« Reply #13 on: September 23, 2021, 06:12:42 pm »
Neat tool but free version is creating improperly scaled files.  10.00 inch wide png is producing a 118.228 inch wide gerber file.  What to do about this?  My png is 300 pixels per inch.
« Reply #14 on: September 24, 2021, 03:49:18 pm »
Hey Pete,
Gerber format used to have an scale factor command which allowed gerber scaling by adding one line in the header, but that command is deprecated since December 2012 gerber format revision, so I guess some software will be able to interpret that command and some won't.
If yo don't need to export drill files you can always purchase the full version of ImageToGerber, it is not that expensive and your contribution would be really appreciated.
Offline Just_another_Dave
« Reply #15 on: October 10, 2021, 08:46:50 pm »
Jordie,
A color picker would be also really useful, as it would allow choosing the adequate colors just by clicking on the different parts of the image
« Reply #16 on: October 13, 2021, 05:08:48 pm »
There's a color picker already implemented, just click on the WhatsThisColor button.
The following users thanked this post: Just_another_Dave
