The OP either can't handle loosing an argument, or is gravely delusional.
This assertion of yours has no basis in fact.
He has shown non of what he claims to be true.
I don't need to show that
facts are true. Every aspect of design transfer when making a PCB (copper etching, solder mask, and silkscreen) is fundamentally the same thing as making/burning a screen for screen printing, or, in the case of the silkscreen layer, it is 100% screen printing. The only difference is the specific chemicals used (though they all function on the same principle, i.e., photosensitive/UV curable). All that's left aside from those things is drilling holes and installing rivets, neither of which require any special skills.
On the other hand examples have been given in the thread of boards manufactured with curly traces.
Show me an example of traces that are 100% analog, from start to finish, i.e., never entering the digital domain. I can do that at home; do you know of a factory that will do it?
Granted gerbers doesn't support them, rasterizing the image near the end of the process is a non-problem.
You're confused. Rasterizing the image near the end of the process doesn't help matters, because software that generates Gerber files doesn't have any means for drawing bezier curves in the first place, because Gerber doesn't support them. The workaround that I was made aware of in this thread is to start with a raster image that was drawn in a different program, such as Illustrator (vector drawing which you've exported from Illustrator as a raster image), or you could draw it as a native raster image in e.g., Photoshop. Then there are some PCB design programs which will allow you to import that raster image which can then be exported as a Gerber file. It's a kludge, but you could theoretically get very good results with it. Of course, that's still not analog, which can be done at home without using a computer at all, for anything.
Also boards with more-than-one-color printing has been shown to exist.
No one showed a factory-made PCB with e.g., a full-color photographic image printed on it, not that I recall anyway. If someone did, please link to it.
By the way, I can make a better pizza at home than any place in my town makes. Mine cooks in 4 minutes on a 3/8" thick plate of steel preheated to 700 degrees F; a 4-minute cook time is the gold standard for making "New York style" pizza. All the places in my small town that make pizza are just Mom & Pop convenience stores which don't specialize in it, and they all taste more or less the same, since they are get their ingredients/supplies from Sysco, and they all use the same type of pizza ovens which take about 7 or 8 minutes to cook the pizza.
