Author Topic: Land pattern notation question  (Read 1230 times)
Offline P_DopedTopic starter
« on: May 08, 2025, 10:34:10 pm »
I'm looking at a C&K momentary SPST tactile switch (gull wing) and the provided pattern has notation I'm not familiar with.  See attached.
In the vertical (from the point of view of the drawings) direction of the pin, the land pattern uses the notation "4-0.7" and in the footprint it says "4-0.5".  What does this mean?  All dimension measurements are mm.
Thanks.
Online thm_w
  • Non-expert
Re: Land pattern notation question
« Reply #1 on: May 09, 2025, 12:20:26 am »
4 locations of 0.5mm for the physical switch
4 pads of 0.7mm for the footprint
« Reply #2 on: May 09, 2025, 01:13:58 am »
That makes sense.  Thanks!
