Author Topic: passive footprints  (Read 7478 times)
Offline DerekG
Re: passive footprints
« Reply #25 on: March 11, 2019, 11:36:52 am »
Simon,
Look carefully at your photos. There is a problem with the solder paste stencil. It is clearly not depositing an even layer of solder paste over the entire surface of the pads.
I also sat between Elvis & Bigfoot on the UFO.
Online SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« Reply #26 on: March 11, 2019, 11:38:12 am »
Well I have already made then closer. As I said the original ones came from a datasheet. Seems the manufacturers are clueless themselves.
