I use PCAD 2006 and a design I have in mind is using identical circuits.
Usually when I see PCBs with identical circuits, the components are all in identical places. Similarly, at my old job where they used PCAD, I saw the same layout when identical circuits were used.
Normally, as with other PCB software, I'd create the schematic first, export the netlist, and then manually move all the components in place.
I'm wondering if a way exists so I can layout circuit A in the PCB portion of the design, and then mimic the component placement traces, etc... for circuit B, C, etc...?
I'm assuming create circuit A in the schematic, export the netlist, move the components on the PCB, and then return to the schematic to copy circuit A and paste it to create circuit B, C, etc... but uncertain how to incorporate this into the PCB portion so the components are all placed identically.
