Author Topic: PCB layout help  (Read 2724 times)
Offline B JTopic starter
PCB layout help
« on: July 16, 2019, 07:16:32 pm »
Please bare with me on this.  I know it has been covered many times, but I am still confused and looking.    ---   Looking for a basic program where I can layout a board and print it out on my printer.  Don't want schematic capture, auto routing or anything like that.  Just want to layout a simple board and print it off.  Several years ago I used a program that was very simple to use.  Can't find any simple ones now.  Tried to download a couple but no success.  My computer is old, slow, and it says that I can't download what I tried.      -----    Suggestions of where to get a very basic layout tool?  What works with a minimum computer, effort and time on my part?   TNX
Offline tautech
Re: PCB layout help
« Reply #1 on: July 16, 2019, 07:50:35 pm »
MS Paint ?
Avid Rabid Hobbyist
Offline ttelectronic
Re: PCB layout help
« Reply #2 on: July 16, 2019, 07:54:35 pm »
I'm not 100% sure, I think big clive uses sprint layout may be worth a try, I have never used it, so I cannot comment. But I think he liked that you could quickly make a board with it.
Online MarkF
Re: PCB layout help
« Reply #3 on: July 16, 2019, 11:18:53 pm »
DipTrace  has the capability to print a PCB layout to a printer, PDF, BMP, etc.
I found it easy to learn and in just a few hours had my first PCB.
Offline DerekG
Re: PCB layout help
« Reply #4 on: July 24, 2019, 05:34:34 am »
I found (DipTrace) easy to learn and in just a few hours had my first PCB.
Fully agree. The OP says he only does simple boards so he can probably use the demo cut down version for free.
I also sat between Elvis & Bigfoot on the UFO.
Online MarkF
Re: PCB layout help
« Reply #5 on: July 24, 2019, 12:14:35 pm »
You can get the FREE for Non-profit license which enables you to do 2 layer PCBs with 500 pins.  Any PCB size.
Just ask with a few sentences saying what you are using it for.  They emailed my license the next day.
I have yet to need more for personal PCBs I've done.  My most complex PCB had 18 ICs (5 28-pin, 10 8-pin and 3 16-pin), 20 resistors and 2 30-pin headers.
I also heavily rely on the 3D view as my last check of dimensions.  I have even created some of my own 3D models with FreeCAD.
Offline nigelwright7557
    • PCBCAD software
Re: PCB layout help
« Reply #6 on: July 28, 2019, 10:16:33 pm »
 I sell pcbcad software and still get the odd "pad and track" people who want to make a pcb simply with no schematic etc.
This is fine for small pcb's.
However, for larger pcb's you really need a schematic which is error checked as a basis for a pcb.
Then once the pcb is laid out lots of error checking needs doing for continuity and clearance etc.
With the onset of very cheap $2 batches of pcb's from China, there is little excuse to go the home made route any more.
In that case a nice solder resist pcb with nice text and neat tracks etc is the way to go.
« Last Edit: July 28, 2019, 10:18:16 pm by nigelwright7557 »
