Author Topic: problem controlling variable DC-DC LTC1261LCS8-4  (Read 3791 times)
Offline john23Topic starter
  • Country: aq
« on: April 14, 2024, 08:58:42 am »
Hello,In the datasheet shown below they say that the output resistance could be controlled using the COMP pin as shown in the links below.
I have tried to simulate this component in LTSPICE.
However I cannot understand the datasheet regarding how exactly do I need to use the COMP pin for tuning the output voltage?
LTSPICE  and phots are attached in the link.( I dont know other ways to present here photos and simulation files :-)
Thanks.
https://www.analog.com/media/en/technical-documentation/data-sheets/1261lfa.pdf
https://ibb.co/WtvMYws
https://ibb.co/vLyCjr5
https://easyupload.io/4s197x
Online iMo
  • Country: li
Re: problem controlling variable DC-DC LTC1261LCS8-4
« Reply #1 on: April 14, 2024, 09:30:42 am »
Your part is not adjustable, it seems..
The Adjustable parts should not end with the suffix -4 or -4.5..
« Last Edit: April 14, 2024, 09:32:19 am by iMo »
The following users thanked this post: john23
