Author Topic: PSPICE Error  (Read 2767 times)
Offline CujoTopic starter
PSPICE Error
« on: October 01, 2021, 07:30:17 am »
I'm trying to do a transient analysis with respect to the BJT'S Collector-Emitter voltage marker.
But I'm getting an "Node $N_0004 is floating" error with the C1 capacitor. Not sure why I'm getting this error and how to fix it?
Here is the error details:
* From [PSPICE NETLIST] section of pspiceev.ini:
.lib "nom.lib"
.INC "Schematic2.net"
**** INCLUDING Schematic2.net ****
* Schematics Netlist *
C_C2         0 $N_0001  10u
Q_Q1         $N_0003 $N_0002 $N_0001 Qbreakn
C_C1         $N_0004 $N_0002  10u
R_R1         $N_0002 $N_0005  80k
R_RC         $N_0003 $N_0005  4k
R_RE         0 $N_0001  3.3K
R_R2         0 $N_0002  40K
I_Vi         $N_0004 0
+SIN 0V 10mV 1KHz 0 0 0
V_VCC         $N_0005 0 DC 12V
**** RESUMING Schematic2.cir ****
.INC "Schematic2.als"
**** INCLUDING Schematic2.als ****
* Schematics Aliases *
.ALIASES
C_C2            C2(1=0 2=$N_0001 )
Q_Q1            Q1(c=$N_0003 b=$N_0002 e=$N_0001 )
C_C1            C1(1=$N_0004 2=$N_0002 )
R_R1            R1(1=$N_0002 2=$N_0005 )
R_RC            RC(1=$N_0003 2=$N_0005 )
R_RE            RE(1=0 2=$N_0001 )
R_R2            R2(1=0 2=$N_0002 )
I_Vi            Vi(+=$N_0004 -=0 )
V_VCC           VCC(+=$N_0005 -=0 )
.ENDALIASES
.probe
.END
ERROR -- Node $N_0004 is floating
Offline T3sl4co1l
    • Seven Transistor Labs
Re: PSPICE Error
« Reply #1 on: October 01, 2021, 11:03:43 am »
Why is Vi drawn as a voltage source but modeled as a current source?
A current source does not define a voltage, nor does a capacitor at DC.  Also, a zero current is identical to an open circuit.  So, the message is exactly as it says; the node is floating.
The implication for simulation is, the solver cannot find a solution for that node; it can be literally anything.  The technical term is "singular matrix", which most other SPICEs call it in the error message.  The solution is to add a shunt (from node to GND) resistance or inductance to define that voltage.  Setting RSHUNT to a modest value (say 1e9) may also do the job, but mind it tends to mask the problem and transient simulation can go slowly due to the resulting poorly conditioned (near-singular) matrix.
Seven Transistor Labs, LLC
The following users thanked this post: Cujo
