Solder wicking is a real issue, especially with small pads, but on such big pads the problem is more the opposite. Without extra pecautions, there is far to much solder paste on the center pad, and this can result in the whole package floating on the solder blob and the QFN pads not being soldered at all.
I added a screenshot of one of the QFN-32 footprints from KiCad. (They come in different pitch sizes) The bright red is the copper, while the greyed out areas are the F.Paste layer (holes in the soldering stencil) So the copper is a big exposed pad and has the via's while the solder paste has 3 smaller pads. This deposits less solder on the big pad (to prevent floating), and the extra ridges also keep the squeegee at the correct height (with a big hole, the flexible squeegee dips into the hole and removes some (unknown amount) of solder paste.
Some of the solder wicking into the via's is (mostly?) a good thing for the center pad of a QFN. It gets rid of "excess" solder. And because the underside of an QFN is flat, it needs very little solder on the center pad. Because this solder layer is so thin it also has a higher capillary effect then the holes. So only the excess gets wicked into the holes.
The rounded corners on all solder stencil apertures are also a nice detail. This improved release of the solder paste when the mask is lifted. (No paste gets stuck in corners). This is also an IPC recommendation, and a DFM improvement.
KiCad's footprint is also not ideal. I have seen footprint designs where all the thermal vias are covered by the solder stencil. This prevents solder paste from being squeezed into the vias (which is a production variable) and thus the total amount of solder paste is better controlled.
I would also not rely too much on a footprint suggestion of some manufacturer. The paste machine, PnP, solder paste and soldering process used are all important production parameters, and these influence the optimal solder paste apertures.
