Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Required clearance for opto-isolated DALI comms signal?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Required clearance for opto-isolated DALI comms signal? (Read 1521 times)
ocset
Super Contributor
Country:
on:
August 10, 2017, 08:07:05 pm »
Hello,
We have a DALI signal which comes into our non isolated offline LED driver. The DALI signal is isolated from the receiver in the LED driver by a TCLT1000 optocoupler..
TCLT opto datasheet
https://www.vishay.com/docs/83515/tclt1000.pdf
The problem is , that its too long to fit on the PCB. We need to use a smaller opto…..
Do you think we will be able to use the LTV-356 optocoupler which is 3mm shorter….
http://www.mouser.com/ds/2/239/LTV-356T%20Series-1308-301539.pdf
Will the clearance still be adequate with the LTV-356 opto? Also, if not, then can we just use a cutout in the PCB to increase clearance like that?
Logged
floobydust
Super Contributor
Country:
Re: Required clearance for opto-isolated DALI comms signal?
Reply #1 on:
August 10, 2017, 10:27:48 pm »
What is your isolation voltage requirement for your product's regulatory approvals?
The product is double-insulated?
Logged
ocset
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
