Author Topic: Simetrix SPICE software recommendation  (Read 1661 times)
Offline ddavideborTopic starter
    • Sideband
« on: August 19, 2019, 05:43:52 pm »
Hello guys,
I want to drop a product recommendation for Simetrix
I have been using this Pspice tool for two years now. I found it much easier to use then LTSpice and similar software. In particular for the following reason:
* the included library is very good, I actually never had to import any components
* The graphs are nice, although not very intuitive
* The Montecarlo analysis is easy to use (it's needed to calculate the effect of component tolerances)
* the included probes are very easy to set up, for example the pre set-up bode plot with phase and gain margin calculation
* Never had weird errors, those that came up were easy to debug
* No writing spice commands (although you can if you want)
In theory, it integrates with Altium, but I have not yet tried
Currently working on the future of Altium library management https://getsideband.com/
Need Altium Designer Libraries? Check out https://getsideband.com/libraries (35k symbols, 34K footprints)
Offline Zucca
  • EE meid in Itali
Re: Simetrix SPICE software recommendation
« Reply #1 on: August 20, 2019, 10:38:51 am »
LTspice is free as I know, how much is this one?
    • Sideband
« Reply #2 on: August 20, 2019, 01:49:30 pm »
Basic version is free, with size limitations, the classic is around 1000something usd if I remember correctly
The other versions I imagine are probably really expensive
