Author Topic: Altium: Via tenting in thermal pad  (Read 15277 times)
Offline TinusTopic starter
« on: October 09, 2014, 11:39:18 am »
Hi everyone,
EDIT: Apologies this should have been in the Altium section.  I accidentally posted it in the parent forum.
I'm busy designing a board using the TPS63020DSJ which has a 14-lead PSON package.  I've added through hole pads (also tried vias) on the thermal pad.
Now my problem is that when viewing the Gerber files, the solder mask covers the vias in addition to the rest of the pad, but I don't want the solder to flow into the vias.  I've tried various things, including the "force tenting on top/bottom" setting on the vias but this also doesn't work.  It looks like the thermal pad settings are overriding the via's settings.
I'm sure this has been done before, could someone please shed some light on how to accomplish this?
Thank you and regards
Tinus
« Last Edit: October 09, 2014, 11:41:46 am by Tinus »
Offline Precipice
Re: Altium: Via tenting in thermal pad
« Reply #1 on: October 09, 2014, 11:56:47 am »
I'm not sure you can (or should) do this.
If you want to plug vias, soldermask isn't the right thing - you want to be screening epoxy into the holes. Dots of soldermask, poorly held onto the top of open vias, in an area you'll be stencilling solderpaste - sounds like a recipe for trouble)
I'd also question whether you actually want to plug the vias in a thermal pad? Giving the solder an escape route tends to let the chip sit flatter and closer to the PCB. There's a risk of solder balls appearing on the back of the board - bit if you give them a bit of copper to spread out onto, that works nicely.
I've done this a few times, and X-rays show good attachment.
(but to actually answer your question - I don't think that Altium allows positive soldermask, just negative. Or, at least, I've never seen it).
« Reply #2 on: October 09, 2014, 12:21:18 pm »
Hi Precipice,
Thank you for your reply.
My first thought was to fill with epoxy but the assembly house recommended to rather tent the vias as they have had problems with the epoxy.  I will have to take this up further with the assembly house.
Offline Precipice
« Reply #3 on: October 09, 2014, 12:55:46 pm »
It's definitely worth checking to see if you can just thieve the solder through the vias onto the back of the board.
(Although TI's suggested layout does seem to like a lot of vias, doesn't it. Hmm)
I guess you could do something with carefully placed fills, lots of rectangular areas where the vias aren't, if you do want to try this tenting lark - but it still feels brave. I bet your assembly and board shops won't promise you the tenting will hold.
Offline Rufus
« Reply #4 on: October 09, 2014, 01:29:00 pm »
Ignoring questions about it being a good thing to do or not the only semi-automated way to generate a solder mask pattern is to pour a copper polygon around the footprint vias in the PCB editor then move the polygon to the resist layer and copy and paste it into the footprint. The footprint thermal pad and vias need to be set tented.
Offline Spikee
« Reply #5 on: October 09, 2014, 02:24:04 pm »
It is also possible to leave the via's untented. Add little squares in the paste mask so there will be a limited amount of solder paste on the pad.
When you reflow, there is so little solder flowing that the via's should be free.
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: October 10, 2014, 01:42:51 am »
Ewwwww...
So what happens when you Repour All Polygons?  You have to redo each and every one?
A "convert to region" would lock the outline, don't think that works on polys though.
Another method would be: fully tent the pad and vias, and draw the soldermask openings manually.  Use circles around the vias, and fill (with traces or regions or fill or whatever) between the circles and perimeter.  An ugly hack.
Soldermask is only logical-OR, so you can't subtract a tent from an already open region, you must do some BS way like this.
Or, preferably... just leave it be, because that's usually better.  I've heard tenting is bad because the vias trap gas, which gets released during soldering, causing voids.  Also better to provide a path for solder to move, as mentioned above: you can even use purposely sized vias to wick excess solder away from the pad, so the device sits at the correct height for all pads.
Seven Transistor Labs, LLC
Offline Rufus
« Reply #7 on: October 10, 2014, 03:07:47 am »
I just played with it a little thinking the recent improvements to polygon management might have made this method impossible but it hasn't. A solid polygon pour around vias on a copper layer needs to be exploded to primitives which turns it into a region which can be moved to any layer. Regions can't be re-poured and it would be a component primitive anyway.
I think in previous versions moving or pasting a poured polygon to a non-copper layer turned it into a region. Now poured polygons unpour themselves as soon as you touch them so exploding to primitives is required, or maybe it always was required.
Or all the solder wicks down the vias leaving none on the component pad - probably depending on what heats up first. I have had boards with the above image built. The only problem was a few solder balls coming through the vias to the other side of the board. I don't know what the best solution is other than having the vias properly (and expensively) plugged.
Online T3sl4co1l
« Reply #8 on: October 10, 2014, 04:48:54 am »
I try to dimension vias (diameter and count) so that the amount of solder wicked (if they fully fill) corresponds to the amount added using a full paste pad over the recommended partial paste pattern.
Offline tszaboo
« Reply #9 on: October 10, 2014, 07:54:39 am »
I would try to delete the thermal pad from the pcblib and manually place one. Also, if the holes are smaller than 0,3mm there will be very minimal solder lost. USually you dont even need to cover the whole pad with paste, depends on the stencil thickness (most engineer just ignores or fails to understand the importance of the stencil thickness.)
