Author Topic: ESP32 board with ripped USB socket  (Read 2570 times)
Offline bitwelderTopic starter
« on: October 13, 2020, 10:59:45 am »
I have an ESP32-based small board (one of those small weather/soil condition monitor stations) where the tiny SMD micro-USB socket ripped off from the PCB.
Instead of trying it to re-solder it, would it be possible to plug just 'at flashing time' a USB-to-UART converter to the ESP32 TX/RX pins, and work it that way?
My hope is to flash there something like Mongoose OS or similar, so that after I flashed and configured it once, in future I could do OTA updates.
Offline m k
Re: ESP32 board with ripped USB socket
« Reply #1 on: October 20, 2020, 09:42:09 am »
If that kind of flashing is enabled then yes.
Connect a terminal and try it.
I read that speed is 115K, mode is unknown but try 8N1.
You should receive something meaningful.
Offline GodIsRealUnless DefinedInt
  • The Implicit None
« Reply #2 on: February 14, 2021, 04:46:21 am »
Wish I was here last year, you can hook GND to GND, power 3.3V to the DevKitC and then USB>>Serial>>TTL level TX to the DevKitC RX and USB>>Serial>>TTL RX to the DevKitC TX. Then ground IO0 (Boot) and press the (EN) to enter programming mode. You should see something similar to:
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
Then in the Arduino IDE you can upload your sketch. I use the same technique on Arduino UNO boards when having reprogrammed the second ATMEL firmware to be a USB HID but still needing to do program the main ATMEL / upload new sketches.
Get yourself the Free book on ESP32 available here: https://leanpub.com/kolban-ESP32 it will help you with your ESP32 endeavors.
« Last Edit: February 14, 2021, 04:53:44 am by GodIsRealUnlessDefinedInt »
Offline oliviasmithh900
« Reply #3 on: March 08, 2021, 12:49:39 am »
it won't be wise to use the usb pins that way, you should go with the default style
