here they are or where used as MEV cashier recordings and against tax evasions loll as you may know since you are in canada
i have one sitting duck on a bench for a long time, don't know what to do with it
yes they have gene 9455 motherboard in them, cant recall the version, 1.1 or 1.2 svga out, not the dvi board model
In thoses we have here in Quebec, they are crippled in the bios, i was able to find an almost identical one, minus the lpt port who does not work at all, they used Crystafontz 2x16 lcd remotes on them
after bios flashing, i was able to install an real XP on them, instead of the embedded one
4gb compact flash drive, they max out at 2gb of ram, witch i have put in it, Atom N270 if i recall
for the crystalfontz lucky you loll, i dont have one, but it will activate once the driver is loaded, it is not supposed to react before a complete boot
This display could be used on your pc once connected to an usb port, and have some lcd display softwares
@op you want it loll pay a small fee and the shipping and have fun with it loll
you can use it outside it's designed enclosure, you need to put it against a dissipating surface for the cpu thick plate, check the ones on ebay ... you'll see
attached photo of how they look outside the enclosure, it is not the same revision tough, the second one is the model you're supposed to have in it
