Author Topic: Monitoring ESP32 power usage.  (Read 444 times)
Offline hamster_nz
« on: June 04, 2019, 12:14:27 pm »
I've been monitoring the power usage of an ESP32+Camera module, while serving images over WiFi, and thought others might find this image interesting:
You can see the module move through various states during startup, and see the power usage during serving an image at about 31 seconds, the "WiFi on" current is about 161mA.
Offline thm_w
Re: Monitoring ESP32 power usage.
« Reply #1 on: June 04, 2019, 09:29:18 pm »
3.3V right. Are you using the example arduino code for the camera?
Would last about 15hrs on an 18650 cell, not too much. But totally acceptable for using a low power 5V or so USB supply and leaving it plugged into the wall (~50c per year).
If you wanted to get crazy, could possibly shut down WiFi based on motion detection.
Offline Electro Fan
« Reply #2 on: June 11, 2019, 08:04:26 am »
Hi, What instrument and software did you use to make and plot the measurements?  Thx
Offline hamster_nz
« Reply #3 on: June 11, 2019, 08:26:56 am »
It is a home brew thing:
- An ESP-32 Module
- A 1 ohm 5W resistor as a shunt
- 24 bit SPI differential ADC, sampling at 60S/s (but could go as high as 4.8kS/s)
- A low noise 2.5V references.
The ESP32 reads the samples from the ADC, scales it to uV (which is also uA), and outputs to the serial port.
From there it is cut and past into Google Sheets to graph the values.
Low tech, but quite functional.
The following users thanked this post: GeorgeOfTheJungle
Offline imagiko
« Reply #4 on: June 16, 2019, 11:16:02 pm »
Why do you need differential ADC module?
Is the device "always on"?  Assume the spike is when the camera is in action? are you trying to optimize for power ?
Offline hamster_nz
« Reply #5 on: June 17, 2019, 12:22:32 am »
1. I am using a differential ADC because I had one handy.
2. No, the device under test comes and goes depending on what I want to test.
3. Yes, spike at about 30s was module serving a picture.
4. ESP32 Wifi cams are not good as battery powered solution, unless they spend a lot of time in deep sleep (e.g. as a weather webcam uploading to a web sevice). WiFi uses quite a bit of power.
Online SiliconWizard
« Reply #6 on: June 18, 2019, 02:17:34 pm »
Using a differential ADC to measure voltage across an high-side shunt seems reasonable to me.
Would probably be handy to have higher sample rate (maybe something around an AD7764 or the like), but that's an useful tool nonetheless.
