The network? Why have only one?
I keep my NAS on a separate network which has no route to the internet.
I like to have a dedicated firewall box between my local networks and the internet. This is the one I put all kinds of shenanigans on, to auto-block all IP traffic from port scanners and such. Internally, I use separate wired networks for hard-wired media devices (for traffic priorization rather than security), another for internal control and sensitive or security stuff, and one for common devices split into a couple of VLANs. I like my WiFi bridged to my guest network, with no IP access to the wireless routers themselves (but configuring OpenWRT thus without a local console is a bit tricky).
Complex? No, not really. I've found that splitting the functionality into separate devices gives me more options, and actually reduces the maintenance task due to each device has a simpler task, and thus simpler internal configuration. (Except for me being me, and adding those shenanigans on top.)
Stuff like traffic shaping is much easier, when it is only about prioritizing traffic to/from the different LANs/VLANs, and not within one.
I do prefer having my wireless routers (for local network) having two separate physical connections: one for the normal network, bridged to the wireless 2.4 GHz and 5 GHz ones, and one control-only local one, so that the router itself exposes no TCP/IP or UDP/IP services on the normal network, only on the control-only wired interface.
In this scheme, there are two different networks and purposes I could add a NAS box to: for media, e-mails and files on the normal network, or for periodic backups et cetera on the control/sensitive/security network. Similarly, I could add a local server (SBC) on either/both networks, home appliances, etc.
If you draw out the entire scheme, it isn't much more complicated than the typical "everything depends on this single expensive router/switch device" schemes. You'll also notice that specific parts of the scheme can be separately powered in case of blackout: the RBM33G firewall/upstream connection draws only a few watts, and that is sufficient to give you wired upstream network connectivity even if the local mains is out. Add another few watts of backup power to the wireless router, and now your tablets and other wireless devices work also.
I'm typically about 1 Mm away from the most important installation, too, so although I cannot afford expensive components, robustness is a must or it just won't work. There, the main user is, uh, not very technical, having had her Fakebook account hijacked twice already; prime phishing target.
