Author Topic: NUC replacement....  (Read 2641 times)
Offline Gibson486Topic starter
NUC replacement....
« on: October 05, 2023, 02:25:09 pm »
Not sure of this is the correct forum, but we currently use an Intel NUC 11 and Intel does not want to say what is gonna happen to it after the Asus transition. We use the TN variant because of the internal serial port header. Mouser says they do not have any indication that the NUC11 is gonna get killed off, but the Intel website says it is due to be discontinued by the end of the year.  Anyone have any ideas of decent replacements that are just as small and cheap? I could just waive the serial port header requirement, i could just get the PA variant, which Asus already supports....it seems like the idea of dedicated RS232 serial is numbered unless I pay Advantech some serious money.  If I waive the serial port requirement, does this essentially mean I need to rely on USB to serial converters?
Edit...Mouser just updated their website....now marked as EOL:(
« Last Edit: October 05, 2023, 02:59:41 pm by Gibson486 »
Offline eleguy
Re: NUC replacement....
« Reply #1 on: October 05, 2023, 07:25:51 pm »
In the previous company we used so called fit-pc. Those are more rugged than nuc(s).
Offline Postal2
« Reply #2 on: October 07, 2023, 07:14:18 pm »
I bought this one:
https://aliexpress.ru/item/32839489621.html
One year uptime without any problem, cpu is j1900, 4G ram is OK, but I set 8G because struggled with freezing, I win over with disable energy-saving in bios.
« Last Edit: October 08, 2023, 12:10:19 am by Postal2 »
Offline MarkF
« Reply #3 on: October 07, 2023, 09:51:36 pm »
I've been looking at these:  MINISFORUM
Similar form-factor as the NUC.  Don't know if any has a serial port.
