Some "OEM Only" drives use the CompactFlash form factor but only provide a 5V IDE/ATA interface.
These will not work in readers or devices which expect a 3.3V interface and full CompactFlash functionality
look at the Seagate ST1
- it perfectly works with the USB_CF adapter, which operates at 5V. Badblocks passed, zero error reported
- it panics on the rb532a at every ATA command that involves the spinning motor and heads (sector_read, sector_verify, etc ...), but it responds to the ATA identify command, which only involves the control board of the microdrive but not the spinning motor
My guess...the rb532a CF module must be 3.3V.
Ordered a 2GB microdrive made by GS Magicstor. Paid 10 euro on eBay.
Magicstor is a Chinese manufacturer subsidiary of GS Magic, Inc..
The datasheet of their microdrives says
- 2GB 3.3V/5V
- 4GB 3.3V-only
According to Google, there is no OEM version.
With Hitachi... it's hell:
not only there are also OEM versions,
but also custom IBM-made versions for their MIPS WinCE-v1.0 laptop (only sold in Japan),
marked "IBM Microdrive" but made with Hitachi parts,
who also made the Apple iPod drive,
and whatever Apple, IBM or Hitachi microdrive you look at ...
... they are not easy to identify as "OEM" or "non-OEM", as there is no indication on the label!
Some Hitachi microdrives made for Apple iPod have a log on the front,
usually the Apple logo, which means it is an OEM drive, 5V only, True-IDE only,
but other Hitachi microdrives have no indication at all.
The datasheet is very vague, and reports approximate things compared to what I observe!
