Author Topic: Pico-ITX?  (Read 3103 times)
Offline JesterTopic starter
Pico-ITX?
« on: December 18, 2020, 10:53:46 am »
I'm really not up to speed on the latest and greatest small form factor Win7 compatible embedded PC's, so I'm looking for advice as to where to purchase a suitable replacement for a dead Pico-ITX board.
The existing software runs flawlessly under Win7 so I simply want to swap the existing HD over to the new PC.
The dead embedded PC that needs to be replaced is a EPIA-P900.  The EPIA-P900 is a Pico-ITX form factor 72mm x 100mm. This ran fine with 2G RAM and a small HD. It used a total of 4 USB ports. I don't really have room for a larger board.
Any advice is welcome. Thank you.
Offline bingo600
Re: Pico-ITX?
« Reply #1 on: December 20, 2020, 09:21:54 am »
« Last Edit: December 20, 2020, 09:23:31 am by bingo600 »
The following users thanked this post: Jester
Online 2N3055
  • Country: hr
Re: Pico-ITX?
« Reply #2 on: December 20, 2020, 09:38:35 am »
I used few Aaeon (part of Asus group) PICO-ITX boards and they worked fine.. I can't attest to longevity, they are now 2-3 years old..
We have yet to see how long they will last..
Also take a look at VIA EPIA-P910..
Just moving HDD to new board would need same board, or board with sufficiently similar processor/chipset, so at least kernel boots, and then it P&P autodetects other drivers...
There is no guarantee you will be able to do that. Sometimes you do, sometimes don't...
« Last Edit: December 20, 2020, 09:43:42 am by 2N3055 »
Dr. Richard W. Hamming
Offline SiliconWizard
Re: Pico-ITX?
« Reply #3 on: December 20, 2020, 11:52:56 pm »
We don't really know what your budget is, nor what specs you're after, although I guess the EPIA board you're mentioning is probably a starting point.
Gigabyte, MSI and Asrock have some:
https://www.gigabyte.com/Motherboard/Embedded-IoT--Form-Factor--Form-Factor---IOT-Pico-ITX-Motherboard
https://www.asrockind.com/en-gb/pico-itx
https://ipc.msi.com/products_list/Single-Board-Computer/Pico-ITX
And probably a bunch of other vendors...
I've used a Qotom board in the past:
https://qotom.net/product/90.html
Not this one, but something similar, and AFAIR, the board was decent and cheaper than your average Pico-ITX motherboard.
Offline Nominal Animal
Re: Pico-ITX?
« Reply #4 on: December 21, 2020, 07:02:12 am »
Maybe Odroid H2 ?
It's manufactured by South Korean HardKernel, and the current one is H2+, costing USD $119 without memory.  It is a bit nitpicky about the DDR4 RAM modules it can use, so see the H2/H2+ Confirmed RAM Modules List first.
I have a couple of other Odroid boards (C1+, HC1), and really like them a lot, but since I don't have a H2 or H2+, I really don't know how good it is.  If I needed a tiny x86/x86-64 machine, I would definitely get an H2+, though.
