Author Topic: SCSI Linux  (Read 2427 times)
Offline rckantaTopic starter
  • Country: in
    • http://www.fimage.ml/
SCSI Linux
« on: July 25, 2020, 05:56:24 pm »
 have installed sg3 utils software.
I want to send a command to the SCSI device (/dev/sr0).
command = ef 01 ff ff ff ff 01 00 03 01 00 05
How can send above command to the SCSI device using
sg_raw?
Thank you for your help.
Offline Nominal Animal
Re: SCSI Linux
« Reply #1 on: July 25, 2020, 10:11:32 pm »
As man sg_raw says,
    sg_raw /dev/sr0 ef 01 ff ff ff ff 01 00 03 01 00 05
  • Country: in
Re: SCSI Linux
« Reply #2 on: July 26, 2020, 04:49:04 am »
As man sg_raw says,
There is error
Sense Information: Fixed format, current; Sense key: Illegal Request Additional sense: Invalid field in parameter list
Re: SCSI Linux
« Reply #3 on: July 26, 2020, 11:25:49 am »
That means that the sequence either needs changing (because it requires data, or produces a response), or is incorrect for some other reason.
Why don't you tell us what it is you are trying to achieve by sending that command sequence?
