Author Topic: Single board computer support  (Read 2202 times)
Offline jashuganTopic starter
« on: August 27, 2020, 01:08:49 pm »
Hello,
what is, in your knowledgde, the single board computer that has the lowest price provided it has a good support? For good support I mean it has the device tree support to build uboot without building from source files.
Minimum requirements are:
  • Cortex start from 1GHz
  • Wifi or Ethernet
  • LCD or Mipi interface
  • better if it has the 2G/3G module
  • better if it has embedded RAM and/or Flash
Offline NiHaoMike
    • Facebook Page
Re: Single board computer support
« Reply #1 on: August 28, 2020, 03:05:43 am »
You can try to find a cheap smartphone that's supported by LineageOS, but the developers don't even seem to bother with the super cheap ones nowadays - a $50 phone takes about the same time to hack as a $10 phone but ends up with much better performance. I'm not aware of any cheaper way to get a cellular radio that supports modern networks - 2G is basically dead and 3G is being phased out.
If you don't need cellular, Raspberry Pi Zero is hard to beat for the low price.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
