I blocked it permanently, but after research, found out it was to do with 'Dr. Web'. The report says...
"DWService enables remote access to systems via just a standard web browser." Hmmm...
what research? https://download.geo.drweb.com/pub/drweb/windows/workstation/12.0/documentation/html/av/en/index.html?settings_avnetwork.html have you checked your RCA is "already enabled"? or is it that Comodo only playing sentimental with you..
Rather don't trust your judgment skills.
why he opted to discard AVAST is a mystery.. if any malicious file is attempted into my system, avast will immediately block it before it even get copied, not after reboot.
[/b]
Firstly, I was told by '
wraper' that this .exe. is not necessarily to do with Dr. Web... Which was wrong.
When you say... "
have you checked your RCA is "already enabled"? or is it that Comodo only playing sentimental with you."...
Obviously, it IS a part of Dr. Web then. And I never noticed any warning/option to have such a 'module/function' enabled.
In my limited capacity, I don't understand the 'snydness' of... "
Comodo only playing sentimental with you." ??
When you say... "
malicious file is attempted into my system, avast will immediately block it before it even get copied, not after reboot"...
Well, obviously, when 'Dr. Web' was first installed, and I gave it
Permission to run & install, all such modules were '
Allowed' to be
present in my system. However, after supposedly totally
UN-installing it, (not completely though as it should have!), there were
REMNANTS left, as in that
.exe file, that Comodo NOW rightly detected and blocked!! (Not sitting on it's laurels before-hand!!)
Now a lot of 'trusted' software will, during a re-boot, COMPLETE it's total un-installation THEN, if it could not do so fully while the System was
running.
However, my main/initial complaint, is that it left this Module behind, and actively running after a re-boot!!! How can I be clearer!!
To those even 'less' initiated than my mere self, this is not acceptable, and deserves reporting as such!
In GENERAL though, regarding what you say about AVAST... YES, for many years it has been a 'leader' for those in the know, as a serious
contender, and quite thorough, with a very low footprint on your system. That's why I used them for YEARS! However!, because they are
a Business and not a charity, their current emphasis is vastly towards constant nagging & pushing for upgrades, beyond what I would label
as friendly/unobtrusive... They CONSTANTLY now throw 'warning' messages to 'scare' the uninitiated, almost declaring their systems totally
corruptible and open to attacks, if they do not immediately upgrade!!! (And quoting tons of false virus/threat warnings!).
'Comodo', (with whom I have zero affiliation with!), ARE a very high end organization. As I stated, it is not for the feint-hearted, as the setup
fine-tuning and utilization can be daunting at first, and not for someone 'new' to computers in general at first. From the start, it never 'Assumes'
anything, and it 'learns' as you go along, regarding YOUR choices & understanding, of what's going on continuously. Assuming you 'know'...
Eventually, you hear less & less from it, and it's all back to 'normal', and although 'in control', it will not let you make a mistake!!!
