I thought this thread (including the Anandtech link earlier) has established that the new Apple SoC is primarily efficient, rather than being the ultimate in absolute performance - i.e. the Intel and AMD processors it is being compared with are able to draw much more power if needed, at which point they blow the new Apple chip away?
Nope.
The M1 is right up there, core for core, against the biggest baddest hot running desktop 125W i9 10900K, 105W AMD Ryzen 9 5950X etc.
It's got fewer cores, of course.
So in the same sense that a 4 cylinder engine is just as powerful as a V-8, cylinder per cylinder?
That comparison would make a lot more sense if cars ran on 1 cylinder most of the time.
My 4-cylinder car with turbo embarrasses most V-8s ever made, while using much less fuel on average.
I can absolutely live with a 4 cylinder turbo instead of a naturally aspirated V8, but if all else is equal (i.e. put a turbo on the V8 as well)... the v8 will be twice as powerful.
I don't know about you, but the workload on my PC is "lumpy"... long periods of light load, and then suddenly a massively intensive task that the user (me!) wants completed by yesterday!
If you are not the kind of user that ever causes intensive loads, then you don't need a V8 or a turbo 4... you are a non-challenging use case. I think that is the target market, initially, because most users fit that profile (most people don't have V8 or turbo 4 cars either).
